FT SR-71 or FT Blackbird
FT SR-71 or FT Blackbird?
  • Total voters
    9
Oh, I WANT AN A-12 OXCART!!!!
Nope, that was an SR71. Dual cockpit for passenger.
A-12 had fins dropping down from the bottom as well.
A-12 is L-O-N-G-E-R
Got it, better do more research.😂. I still think the sr-71 looks better with the shorter fuselage.
Hmmm Palmdale, driving down 14 and getting buzzed by odd assorted secret whazzdat takeoffs.
people who know said an engine out was was difficult to restart after being pinned against the opposite side of the cockpit. Hence the dorsals. You'll note that proper ones have full flying rudders which will allow sideways flight
quorneng
Doesn't matter which.
You will still have the intake cone size problem if it is to be powered by EDFs unless you have "fake" cones or use enormous cheat holes....yuk!
The real one uses cheat holes at low speed to get more air behind the cone.....
quorneng
Yes but they are far too small to adequately feed an EDF in conjunction with the limited cone inlet area.
It seems to be overlooked that cheat holes although convenient are not a particularly efficient way to add air to an EDF inlet duct
Reason the cones are there was the original design engine had sort of somewhat subsonic air intake requirements. Things get stupid at mach 4+ so they stayed. People that I knew that flew these said a relight every so often was a mandatory flight requirement. A no relight flight was akin to a smooth no bounce landing: once every once in a while is great, after the third one, you are tempting fate to smite you.
You don't need a cone, just a profile triangle would suffice for looks. If they wings are too small then you just need more thrust
