Ft Storch motor.
DWH
I have a 2830 1000kv motor from hobby king. Will this motor work for the storch. What prop should I use.
tamuct01
It should be fine. The Storch is recommended with the C Pack motor. The old version was an Emax 2215-900KV and the new pack is a Radial 2218/1180kV. I would run this will a 9x6 or a 10x4.5 prop on 3S. I have the old C-pack motor and my Storch balances out great with a 2200mAh 3S battery. The 2830 motor will likely be a bit heavier than the C Pack motor options, so be sure to check your CG.
