Latest update.
Checked the throws against the values you provided jpot and they were actually pretty close. Examined the plane again to see what else might be amiss and discovered that I had no thrust angle on the motor. Added a little down and right and today she flew a lot better. I had to use the 2200 mAh and a couple of oz additional weight to balance her (like last week). My experience is that you have to fly her four channel, the rudder isn't a luxury or option, you have to use it.
Because I was more comfortable with her today I took her up a couple of times. I think that I am going to move the motor forward, or servos back (or both!) to see if I can get her balanced on a 1600 mAh 3S because I think she would do even better with less weight.
Looking forward to seeing what you will do with the re-build.
DamoRC
DamoRC
