Ok, the fuse has been built. I did not see any issues with the build.
Well, no issues for most folks. I am going to have to rework my power pod for that monstrosity of a motor I am planning on using for this build, but you will not have this problem with a C-Pack motor.
I have to keep this quick as I have to go visit my pops here in a few, but I will add a 3D model assembly later.
First cut the fuse parts as shown.
Draw a reference line level with the two top plate notches to align the Fuse Doublers.
Glue on the Fuse Doublers as shown.
Glue the Fuse sides perpendicular to the bottom plate. This is a "B" fold. I need to mark this on the prints.
Glue the bottom rear into place and cut out the Stab slot and vent hole.
Glue the Fuse top plate into place.
Using the print template, score cut the Pelvic Fins slot into the fuse. Optional.
Cut out the wing cavities.
Install the Power Pod and skewer into place.
Cut the Pod Hatch pieces as shown. Note all score cuts are bevels except for the front tab which is a break.
Glue the hatch together as shown. Note the front tab, fill the break cavity with glue and hold straight until cured.
Once ready, you will add a tape hinge at the back and a small piece of velcro on the front tab as well as the bottom of the power pod.
I would not tape the hinge in place until you are finished with the build. After paint and such.
Sorry for the long post, I am really should just wait and do a build guide proper, but that could take a while.
