Check your prop, power pod and firewall. If you have any damage to the firewall and power pod make a new one.
Also check your battery cell voltages. You might have just run out of power and the ESC is cutting the throttle to 50% to save the pack. A good lipo tester which can read individual cell voltages is a good investment and ALWAYS run a timer on the TX that beeps when you have at least a minute before the battery is flat enough to trigger the esc cutout,
Also don't forget to check your motor. If it feels loose or doesn't turn easily you might have foreign objects stuck in it or damaged a bearing.
Depending on the motors construction the bell might have been pushed into the stator which will also cause extra drag..
You also might have broken or shorted one of the windings. The motor may still spin up on just two phases, although hesitantly but you won't have any power.
