FT Tutor 41.5" (1055mm) steerable nose wheel?
Masterguns
Searched the threads & no specific answer to this question. Someone certainly has done it, and if so, what was your method? Seems easy enough to copy other trainers workings for a separate steering servo with a Y harness to the rudder rx port. Or, couple two push rods with a single heavier & higher torque rudder to NG. Just have to delete the rear fuse mounted rudder servo & install it inside. Kinda like the EFlite Apprentice is set up. Cheap enough scratch build to try. Any pics to share if you've done a conversion? Thanks.
Best Regards,
Masterguns
Foamforce
Best Regards,
Masterguns
There’s a nice looking design for a 3d printed one that could work. If I did this, I would certainly use a separate servo for steering. If I had a free channel on my receiver, I would use that instead of a Y. That way I wouldn’t have to worry about getting my servo orientation to match the rudder, and I could trim it separately. Rates could be set up differently too.
Masterguns
That looks like a nice, functional design. How long might it hold up is my worry, but these planes are low cost, going to get banged up & ugly at some point anyway & I still have 3D printers with the files saved. Downloaded. Looks like you can just wiggle in the angled flanges as a single unit & then secure the wire & associated hardware on from the inside of the fuse. I'm trying to visualize how the back of that mounting plate would mount to any part of the tricycle option configs. I reckon I better start building from the FTCA plans I grabbed first, huh?! Hehe. Thanks for that link, feller!
Best regards,
Masterguns
Bricks
One of the simple ways to do it is find an old plastic cutting board ( thicker ones ) it can double as the firewall. Drill hole thru it top to bottom for the landing gear wire a couple of locking collars and locking control arm. Me would run it from one servo using push rod with threaded end for adjustment.
Masterguns
even rtf nosewheels can be fragile. nature of the beast i guess
You got it. Depends on the brand of the company, how well they design & what parts they use plus the quality. Don't forget the pilot's degree or style of landing habits. Mine aren't the best yet & I don't know how many HH Hobbyzone Aeroscout nose gear assemblies I've trashed because I can't get the hang of the proper'ish method of speed & flare married together at the same time yet. I might be going through a few sets of the linked 3D design, but, again, I'd rather fumble a few cheap Tutors than a several hundred mass produced brands many of have in the collection. Peace.
Best regards,
Masterguns
