Random_rc
Hello,
i have build a FT Versa a while a go. i finally got round to flying it.
when i launched it the first time at about 70 % throttle it went about 10 meters and nose dived right into the ground. so i tried again but with 100% throttle and it did the same thing. i did this about 5 -10 times and i was throwing harder too. I still couldn't get the plane to fly, it was like it didn't have enough power, but i powed the Versa with full throttle and thought it was fine. the servos were working. i have now broke it so much its like a mini blunt nose and can't put the battery in because the battery strap ripped through a chunk of foam. and been in Australia the Foam is about $7.50 each sheet. it was a pusher style.
Specs
Motor: Hextronik 24gram 1300Kv
Propeller: APC Style 8x4 (the ones you can get from Hobby-king)
Esc 30 Amp hobbyking (the blue one(i had from a previous plane))
Battery 2200Mah
Servos: HXT900 9gram
i don't know why it keeped crashing, i was pulling full up elevator (checked that it was the right way
please can some one help me!
Specs
Battery 2200Mah
