FT Versa wing build trouble
laydenBlackwell
I recently cut printed and cut out all of the parts for the wing on foam board and while I was watching Josh Blixer's build video I realized that his parts didn't match mine, is that an old version of the pane?
I have included the plans for my plane below.
  • FT-VERSA-TILED-PLANS.pdf
sprzout
Knower of useless information
Those plans look like the same ones I've used to build about 10 or so different Versa Wings. If you're watching the original build video, he's using a speed build kit and I THINK the build video talks about how there's a fold that's introduced so they can get the packaging to be smaller and cheaper when sending it out. That said, it's been a while since I've watched the video, so I may be mis-remembering it.
Are you trying to build it in tractor configuration (with the motor and prop at the front), or in a pusher configuration (with the motor and prop at the rear)? I know there's a supplemental video for doing it in pusher configuration, and the plans are missing the power pod for tractor configuration...I've never built a tractor configuration Versa Wing, though, because we all fly ours in pusher configuration for our combat events - keeps it from having the streamers tangle in the motor and burn up.
makattack
Winter is coming
There was also the original Versa and the Blunt Nose modification, which may be a separate plan for just the blunt nose component.
