FT Versa Wing electronics question
El gato
The Versa Wing flies great, this is my setup:
Motor Tower Pro 2408 -21 1400kv
ESC 35A EZ Flite
9gm EMax servo
Prop 8x3.8
Battery 2200ma 3s
I used the heavy battery to balance the CG
Flight time will vary depending how you fly it. I usually can get approx. 10 minutes.
This works for me, but you have many options.
Hope this helps.
El gato
Muhammad,
I scratch built the Versa Wing with DT foam. It is an easy build and only uses two sheets of foam board.
The plans were tiled and it's not very difficult to tape them together.
Good luck with your project.
