As it is one of the recommended power packs with the Versa Wing I don't see why not. The big thing you need to be sure of is that you put the right size prop on it, smaller than what ships with the C. Otherwise it's going to strike the wing. That is unless you blunt the nose and put a wide section between the wings.
I'm actually planning on using the power pack C with a smaller prop in a pusher form on mine after I build my Storch.
