jamboree1
I'm suspecting the power packs will be the same. Look for about 7 minutes of flight time on average
devindied
SEL MEL CFI CFII MEI
I'd make a suggestion. Go to Hobbyking.com and buy your own components. I think you will be happier with the options to chose your own equipment. If you need suggestions, let me know.
PS, dont make the mistake I did when I first ordered. There are 3 stores(if you live in the USA) to order from. USA E., USA W, and INT. If you order from INT, it will take awhile to get here, and depending of what you order(size, weight) might cost more(small parts are very cheap) If you order from the USA locations, you will get them faster. However, some items are only available from the INT store. Keep that in mind.
CHEERS!
