Hi everyone, hoping you experts can advise me on this build. So i purchased the Versa Kit and it came with the suppo motor. (which is different than the one in the video) Unfortunately they didn't come with screws to mount to the firewall. I was wondering what can I use as screws or blot and nuts and which ones specifically to mount the motor. The other question is I went to a local hobby store and they didn't stock the 500mah 2c 20 instead they had the 1000mah 2c 20. will that still be ok to use? I also purchased a deans connector that I was advised I will need to cut the ends of the battery and solder on the deans connector called the ultra plug and use that since it would be better.
Thanks in advance for all your help and advice. Looking forward to taking this out for a flight with my 11 year old.
Shadi
You can use the mounting screws that come with your servos (those are the longer ones) to attach the motor to the firewall.
The 1000mah battery should be fine. I'm not sure what suppo motor you have. If you could list the specs it would be helpful. If the motor can handle a 3S (three cell) battery I would recommend that. The Versa will fly with a 2S, but it can be a little bit of a handful for a new pilot as it is a little under-powered.
I would stick with the JST connector personally. I'm not sure how popular the deans t-plugs are, but I know they are more expensive. I prefer to use XT-60 for my bigger LiPos.
