Last night I gave the Viggen a go right before sunset. I plugged it in and tested the surfaces, checked CG... all good. then got the throttle up and threw... and watched it arc to the ground, which bruise the nose a bit.
then I ran through the check again. Do you know what I missed?
I never checked thrust direction.
then I said to my son, like chevy Chase in NLPCV, - "We checked that already I know I made sure that was right" specifically because this model closes it all up.
Then I remembered. I did check it. before I closed it in and had the propeller explode (puncturing the shell here and there.). Fortunately Had two of these so I grabbed the other prop and sanded the rind smooth to ensure proper non-exploding operation. (most likely caused by my non-perfect cutting skills. I put it all back, but I never retested motor direction. :black_eyed:
Back it was as the sun set with a quick pair of incisions, and a prying motion, the connections reversed, Motor direction confirmed correct, and NOW it's ready for a Maiden flight tonight unless NC weather strikes again like it did Sunday and all last week (3:30-4pm downpour).
I will have two Batteries ready and everything.
I think I need to change where I live, so I can test in my backyard.
