Yay - another viggen in the works!Getting ready to pull the trigger on this EDF Viggen build. Looking at a powerfun 70mm 11 blade EDF with 3300KV motor, 80A ESC and a 4s 3300 mAh Lipo. I think this should be a decent setup for my 1st EDF jet.
Ok, so I think I’ll do a kfm wing like @BATTLEAXE did on his prop-n-slot jets he’s done. And since funds for the hobby are pretty low after getting ftfb for winter flying, I think I’ll have to do a prop version. I’m actually considering doing a c or b pack instead of the f pack since I haven’t seen anybody do that yet. I may make it interchangeable so I can try both out.
Be ready for it to be a fast plane. The F pack allows for a lighter battery and a higher Kv. @Photo001 Viggen did really well on the F pack. and the motor will be right in the back which equates to a lot of tail weight. The KFm wing will help to compensate for sure.Ok, so I think I’ll do a kfm wing like @BATTLEAXE did on his prop-n-slot jets he’s done. And since funds for the hobby are pretty low after getting ftfb for winter flying, I think I’ll have to do a prop version. I’m actually considering doing a c or b pack instead of the f pack since I haven’t seen anybody do that yet. I may make it interchangeable so I can try both out.
@Bavarian_RC has a sweet Viggen EDF style and that thing cooks, a sweet speed machine.I feel each part isn't all too expensive but i don't have any of the required electronics so after the fan, motor, esc, servos and a new battery on top of it all it will put me back about $120. All on a $3 air frame. I think going with the C pack will be a nice choice. Maybe you could put a TV mount on it.
For me i had to do the EDF just to know what its like. Got the plans printed so will start cutting soon.
Awesome! I’m still debating whether to buy a 64mm edf or go with the prop/thrust vectoring setup. I need my buddy to fix his 3D printer! 😆
Are you doing thrust vectoring?
Do the KFm thing man, I keep suggesting it and every one is scared of it, yet complain about how weak the wings are in a single layer FB. I did it on 4 versions of the prop and slot jets and it worked out fantastic. You will only benefit from it in strength and lift... and yes they will maintain inverted as well. Check I out on my YT channel, link in the signature.
Prove to these dudes that it is a good idea, they don't believe me lol
Judging by some of your maidens I would swear aerobatics are your thing JKI will be trying to just give it a normal FT style flat bottom airfoil. I'm not too worried about inverted since that's not my flying style, maybe a few rolls and loops and I'll be happy. 😁
Unintentional aerobatics for sure.
Lol🤣🤣Just when you think you weren't good enough to do an inverted loop, it does one for you. Making you look like a pro
Lol - I’m trying it man! Do you think you could take a screenshot of the whole wing and show how big the top layer would be?Do the KFm thing man, I keep suggesting it and every one is scared of it, yet complain about how weak the wings are in a single layer FB. I did it on 4 versions of the prop and slot jets and it worked out fantastic. You will only benefit from it in strength and lift... and yes they will maintain inverted as well. Check I out on my YT channel, link in the signature.
No TV for this one. I want to keep it relativly simple. My only change will be laminating a second layer to the wings for added strength.
As I mentioned before on my Viggen, add some wing area(got added 12.5 sq inches) by just redesigning the angles so it is further out, yet the fuse and control surface points are the same.
Will make for a slower landing speed.
Another clean build so far, looks sharpEDF is here. Seems like i will need to work on my soldering skills to get power from the ESC to EDF.
I learned to solder in Electronics class in High School. Super careful with the soldering iron, just enough heat to do the job. Very precise and pretty difficult. I was having a bear of a time soldering the connectors necessary for these birds, when my uncle, @sundown57 shared a bit of wisdom. Not a soldering iron. A soldering gun. High heat. As high as it will go. Use the flux. Not just the flux in the center of the solder, actually use a can of flux and liberally coat either end.EDF is here. Seems like i will need to work on my soldering skills to get power from the ESC to EDF.
