Here's mine, I'm kinda a bad painter but I think it turned out alright. Powered off of an F pack equivalent with thrust vectoring, and it flies beautifully.
View attachment 183084View attachment 183085
Zero clue where I got the STL from because that was 5 years ago lol. If the thrust vector bracket is not earlier in this thread then I probably just found the bracket on thingiverse somewhere.
I did my Viggen with a 64 mm EDF with a Thrust Vectoring Nozzle for 2 axis. If you go down to a 50mm, doubt that you could find a 50 size TVN. You would have to make one.
A 2 axis build TVN (elevator and yaw) is a pain to make. Used that on a modified B2 Spirit. Better off just putting a vert for yaw inside the duct.
I position the EDF forward enough with TVN at end so that I did not need up canard and got it re-zero. Since the wing is so large rolling was very slow. I put 2 servos(one in each inlet duct) to activate additional roll and pitch from the canards but found out the Viggen would be much better with an 6 S 80 EDF. Pics available.
I plan to build one of these as my first EDF, not right now, I’m not in a hurry and got a few projects to do first, plus improve my flying skills first.
But do you think the V2 plans will be available this year - if so I would hold off until then?
This is a list of plans @SP0NZ is getting ready.
The Viggen V2 is at the top but it doesn't necessarily mean it will be released next, but we can hope. 🤞
