GlassL
I've noticed after building both wings for the Tiny Trainer and looking at videos of other model builds that the wing are all designed with a main wing as a closed Clark Y style (cambered top and flat bottom) but the wing tip end up with an open under camber. Is this do to give the wing washout by increasing lift at the tips so in a stall the main wing section stalls first causing a nose down pitch before the tip stalls? I am use to the older balsa kit designs like the Telemaster or Kadet were you have a flat Clark Y airfoil form root to tip.
