Here is a video of trying to find the right value of CG for the swept wing. Way different then calc.
The reason you should start off with the EDF rather than prop is the EDF is protected and no major damage occurs. I have done props in front, in fuse and at the tail end, each has caused damage when the prop strikes(running or off) especially if you are checking out the CG.
Here is a video showing where I had to move the battery forward trying to find the proper CG.
