FTFC’26 Build-Ruary Contest RickHunter
RickHunter
Build Skill: 4 (Skilled) I can build it all, but I have never designed (have modified though)
Pilot Skill: 4 (Skilled) I Have flown a little of everything electric, and not afraid to crash
Planes to build:
1) Mini Sea Duck (6s version) https://forum.flitetest.com/index.php?resources/mighty-mini-sea-duck.388/
-Love the Sea Duck. Great flying plane, and have wanted to do a Mini version for awhile now
2) Radjet (6s version) https://forum.flitetest.com/index.php?threads/foamboard-radjet.78500/
-Need to fly the regular one first before doing a possible 80mm conversion
3) nnP-39 (4s to start, then 6s if she survives) https://www.nerdnic.com/nnp-39.html
-Never built a @nerdnic plane before so looking forward to it
4) FT Legacy https://forum.flitetest.com/index.php?threads/sp0nz-plans-index.17136/
-High wing planes are what started it all for me, and need this to match my 200% Legacy
RickHunter
This build process was pretty much the same as the original with just a few differences.
First change was that i put a carbon rod as a wing spar. Probably not needed, but I had it so I used it. This was also going to be 6s powered, but one of my 60a esc's was toasted so it will only be 4s now.
Next change came in the wing servos. I really don't like gluing servos in unless necessary (or I'm lazy), so i printed servo mounts. I will post all my STL's at the end of this in case anyone wants to use them.
The tail booms were built and installed just like the originals, minus my servo mount and a 3mm carbon rod between the two booms (again probably not needed).
Don't forget to run your wires through the wing before gluing on your tail booms. If not you will be going on a fishing trip to get them through. Ask me how i know. 🤨 I also printed out mini firewalls for the pods which worked great.
The body build went exactly as the original. I did a few great mods to it, some thanks to suggestions from the original build forum.
1) lowered the battery tray to make it easier to fit a battery in. I just doubled the edges of the tray length and it worked great.
2) Made the top hatch completely removeable. Weather you do it like mine or like Jo's, this is a absolute must in my opinion. Thanks to @Jo's squadron for this Great idea.
3) Added some air intakes to the top and bottom sides for battery and esc's cooling.
4) I printed some skid plates for the bottom. I live in a desert and have no where close to fly off the water, so it will be a belly lander.
I have already built six regular Sea Ducks, and even one 200%, so everything went very smooth for me overall. This took about 6.5 hours to finish, but 2 hours of that was printing and cutting out the blueprints. Now that I have them, the build process will be much quicker.
Build Difficulty Rating: 3.5 out of 5. You should definitely have a few builds under your belt before trying this.
Flight difficulty Rating: 3 out of 5. Get your rates and expos in her and she is not to hard to fly, drop it down to 3s for even more gentle. She's a fast lander, so watch it.
Motors: 2208 1800kv (it's what I had)
ESC'S: 40amp esc
Propeller: 5x4x3
Final thoughts: I love the Sea Duck in any size. Wish I had more time on the sticks on this one, but what can you do. She will now be in my hanger for a long time to come. As small as she is it's easy to take almost anywhere with you. Not a good 1st plane to go with, but not too hard of a flyer. Fast landings, but was able to get her down in one piece. Once with a bad battery with no power, and even once with a bad elevator servo (not completely out but sticky and glitchy). Can't wait for the flat spins on this one. The build was pretty smooth going. So if you've built a few foamies, you will have no problems with this one.
STL files: Added below. Except for the cowlings since I did not design them. But here's the link: https://www.thingiverse.com/thing:3925766 This is for the regular Sea Duck. I printed x and y at 69%, and z at 67% for a real nice fit on the Mini. https://www.thingiverse.com/thing:3027753 These are the control horns I like.
Any questions just let me know​
  • Mini Firewall.stl
  • Mini Sea Duck Magnet holder 2.stl
  • Mini Sea Duck magnet holder 1.stl
  • Servo Mount Tail.STL
  • Servo holder wing.stl
  • Servo holder mount.stl
  • Mini Sea Duck magnet holder 3.stl
  • skid plate 2.stl
  • Skid plate 1.stl
RickHunter
This one is a super fast pusher plane designed by @Mr Man . I used the build video by @Houndpup Rc to guide me along with the build process.
Building the fuselage was pretty straight forward process. Just a little trimming here and there for a good fit. The fuselage will be covered in packing tape after paint to add a little more strength to it. This baby will be fast, and I don't want any Rapid Unscheduled Disassembly in mid flight. Isn't that right Mr. Man. :oops: :ROFLMAO: Was going to add 3mm CF rod to the fuselage, but decided to just use tape after HoundpupRC's held up with that.
Canopy hatch will be held on by tape on this build. I am out of magnets. I believe Mr. Man made a magnet canopy on his radjet, so you can do it that way if you prefer. If i had any magnets left, it's the way i would do it.
I used 17g Metal servos in this build, and just glued them in. I didn't have any proper 3d printed servo mounts to fit 17g servo at the time, and it is a pretty tight fit. But they fit in there "like a glove."
Due to my thicker spar, I had to do a little extra trimming to fit the esc cover, but it was no big deal. It will be hot glued on after paint and finial assembly.
I printed a motor mount to fit the Radjet, with a 2 degree thrust angle (we will see how that works). If you don't have a 3d printed, HoundpupRC shows how you can make your own on his build video. I also did a slight modification to the Skin #5 because i found it easier to glue the top up at the end with the motor mount. This is totally up to you.
Mr. Man did a great job on the plans, and made it a pretty easy build. If you have done a couple foam builds before, you should have no issues with this one. Flying this may be another story though. If your gonna fly it fast, I believe you need to be an experienced pilot, or you're gonna pry loose it. I will maiden this soon myself. Plus at 150+ mph you don't want to hit anything, or worse, a person with this. I did see HoundpupRC does a 2306 version of this, if you want a more mellow flight. But even this looked quite zippy to me.
The build took about 3.5 hours. This included the stitching of the plans, blueprinting them, building, and estimating the paint time (not including drying time between coats)
Build difficulty rating: 2.5 of 5. Mr. Man does a great job making this a pretty easy build. Especially considering the speed this thing can do.
Flight difficulty rating: 4.5 of 5. You better of drank you coffee before flying this one.
Motor: 3536 1780kv
ESC: 80amp
Propeller: 8x6​
Final Thoughts: It's hard to give final thoughts on this one since I only flew it for about 10 seconds. So I say what I think I did wrong. I think I had my buddy toss it at too high of an angle and I stalled it out. I believe that this had enough power to push out of it, but I was too "throttle nervous." If I would of just gave it more juice I don't think it would of stall. But by the time I pulled my head out of my you know what it was too late and I was on my way back down to mother earth. I did luck out in that she will be a pretty easy fix, but I just won't have enough time to fix her before the end of the contest. Once I get a few Flights under my belt, I think I will start launching her like the Bell X-1 from now on (which should be lots of fun). This one is definitely built for speed.
STL files: Added Below https://www.thingiverse.com/thing:3027753 These are the control horns I like
  • Radjet firewall 16x19 2degree downthrust.stl
RickHunter
This one was very similar to the flite test warbird swappable series as far a building. The wings, stabilizers and canopy were the biggest differences. The build video on this by nerdnic was very good.
I like the aluminium spar the he uses because it helps keep the dihedral bend in the wing. When i build the FT warbirds, i just use a CF rod and keep the wings straight (which they fly good still).
The wings and stabilizers on this build were a little more difficult than the FT Warbirds, but just take your time and follow his instructions and you will be okay. If you're not to sure on how to do them, i would start with the stabilizers first just in case you make a mistake. They will be quicker to recut and try again than messing up on the wings. Mine were not perfect in anyway (kinda ugly actually), but good enough for me.
I used DTFB for this build, and i didn't feel like having to minwax first and then paint it, so i went to my go-to DT reflective tape. Little more weight, but no big deal. If you use this tape (or any other tape), i found it much easier to put on the tape before final assembly.
I do like his battery hatch and canopy design. I hate bottom load batteries, and modify my FT Warbirds very similar to his to always be top loaders. The canopy is off center, but we will ignore that.
I also put BBQ guide/protectors on the inside and outside of the plane. This definitely helps protect the plane and pod from stripping out after multiple landings. Especially the hard ones (not that I ever land hard).
My only issue with this plane is the wing servo's. Due to the fact that I only fly on asphalt or hard packed dirt, they will drag on landing, and will break without protection. If you belly land on grass or put landing gear, you shouldn't have this issue. I put a few printed skid plates to solve this, but they didn't last past my first hard landing. This is why I only flew this on 4s even though I did build this originally to fly on 6s. I will be printing some custom skid protection for control arm protection in the future, so I can fly this on its intended 6s setup.
This build was not a bad one at all, and took about 5 hours to complete.
Build difficult rating: 3 of 5. If you've built a couple planes before (especially FT Warbirds), this should be not problems
Flight difficult rating: 2.5 of 5. This would be a good first warbird for you, and was easy to fly on the 4s setup. 6s TBD
Motor: 3536 1450kv (its what i had)
ESC: 60amp (could go 40 or 50 if your only going 3s or 4s)
Propeller: 9x6 (10" would pry be better, but I live a mile high too)​
Final thoughts: Overall on the 4s setup, it flew very close to the FT Warbirds (mustang, spitfire, and p-40), so if you like those, you will like this one. My only complaint was the position of the servos that will easily scrape the ground on belly landing. This will be fixed very easy when i print some better protection for them. Again if you use landing gear, or belly land on grass, this should not be an issue. I am really looking forward to flying this on a 6s setup in the near future to really open this plane up.
STL files: https://www.thingiverse.com/thing:3027753 These are the control horns i like. https://www.thingiverse.com/thing:2542362 This is the firewall I use (PETG)
RickHunter
This one is a really solid 4s flyer. I built it almost exactly like the FT build video with just a few changes.
The plane wing was built with no dihedral, so i used a 10mm CF spar I had laying around. I also put 3d printed servo mounts in the aileron, flaps, elevator and rudder location instead of hot gluing them in. Also a steerable tail wheel setup was 3d printed as well. The V2 version now has the steerable tail wheel, but i prefer this one.
This was made with DTFB, so i used DT reflective tape. This saves time by not having to minwax the plane before painting. I live in a the Southwest, so i don't have to worry about humidity warping as well. It is easier to put the tape on before final assembly.
I used wire extensions to place the esc behind the battery for ease of access for the battery. Placing the esc under the Power pod is not available in this build.
Also put an air scoop on the top hatch for cooling battery and esc, along with BBQ reinforcements on the skewers.
The main modifications that i did was to the landing gear. I 3d printed the main landing gear mount from the original and used it, followed by another just a little wider that fit on the outside of the body. Then i printed the landing gear setup that I found on Thingiverse. The shocks are 110mm rock crawler shocks I purchased on amazon for less than $20. The landing gear base was hot glued on, a bolt through the top, and screws through the bottom for reinforcement. Not including the bolts that came with the shocks, I used control rods to put the landing gear together. The wheels were some old ones from a Timber Evolution. The gear was not quit even when the plane sat, so I printed the white blocks to straighten them out, and works great.
This one took about 4 hours to complete. I already had the blueprints made, so you might add another hour or two if you do not.
Build difficult rating: 2 of 5. Don't be fooled by its size, she is a pretty easy build. Just the basics.
Flying difficult rating: 2 of 5. She flys nice and easy. It's not easy to do, but she will stall on you, but very easy to recover from.
Motor: 3536 910kv
Esc: 50amp
Propeller: 13x4 (I live a mile high, so if your sea level maybe drop it an inch)​
Final Thoughts: This is a really fun and mellow plane to fly. No really bad tendencies that I have experienced. I have flown both the single and twin motor setups, and like them both. The twin being more sporty, and you can never go wrong with differential thrust. If you use flaps on this, use a little down elevator mixing to keep it level. The single motor setup is still a great flyer. Just make sure not to use too small of a motor. I personally think a 2218 is too small for a single setup. This plane is a great STOL plane, and good for rough landing strips. She is definitely one worth having in your hanger.
STL files: Added below. https://www.thingiverse.com/thing:2542362 This is the firewall I use (PETG). https://www.thingiverse.com/thing:5025624 These are the landing gear I used (PETG) along with 110mm Rock Crawler Shocks and old timber evolution tires. https://www.thingiverse.com/thing:2740764 The air scoop I used. https://www.thingiverse.com/thing:3043957 Tail wheel print i use
  • bbq guide.stl
  • big bbq guide.stl
RickHunter
Got everything done but the 200% Legacy. But that one was just a extra anyways. Gonna maiden the last two tomorrow. Will post video and finial thoughts after that. Hopefully finish up and maiden the 200% Legacy by next weekend. I need it to launch the winning plane of the 2026 speed challenge with. lol. 😁😁
FoamyDM
Building Fool-Flying Noob
Good stuff. Impressive effort. This is time, for contest scoring. best of luck with the maidens.
Is the speed challenge going on still?
FoamyDM
I need another plane like i need a hole in my head… but i do have one in need of a faster motor.
Oh, and thanks for joining this year. Maybe we meet up at FF this year
