FTFC'18 WWII Curtiss-Wright XP-55 Ascender Designed by LitterBug
rockyboy
Skill Collector
Here's a simple way to reinforce the pivot hole and distribute the load better for the front control surface.
Can be set up parametrically for different thickness of foamboard and different diameter skewer/pivot rod. Could also come in handy for reinforcing the skewer holes on planes with rubber band mounts....
Cheers!
That would be very handy for all us canard builders! Do you have it posted on Thingiverse or Onshape or somewhere?
Thanks!
HilldaFlyer
I agree! Simple KISS.
I have a 3D printer so that would be great. Lighter than plywood and nose gear steering mechanism.
Good job. Now put it into the Ascender.
I created a parameterized OpenScad script to generate them. This allows for easy adjustment of material thickness and pivot hole diameter. The code generates a matched pair for a tight fit. I can post up the code, but it may be beneficial to generate a few different standard size pairs as well for those not wanting to mess with OpenSCAD.
Code:
// Foamboard Thickness in mm
Fthick= 5;
// Holesize in mm
Hsize= 2;
What would be some good sizes to pre-generate and post up with the code? Maybe single and double thick foamboard and a handful of like 2-4mm holes?
Cheers!
HilldaFlyer
Printing some test versions out to make sure the geometry is OK. Will post the .stl files up soon.
Cheers!
Foamboard Hole/pivot reinforcements
Made some mods after printing them out and actually trying one on a piece of foam board.
Made the press fit looser. Figured out it is better to have a short part to press into, so that it can be used either flat tword the foamboard, or the sleeve tword the foamboard, Also allows for variance in material thickness.
Files can be found:
https://www.thingiverse.com/thing:2609255
Please check them out and provide feedback on how we can make them better!
Cheers!
