Well my burst of inspiration on the Do-635 died the death of priorities and shifting interest. Nice as that aircraft is, it's a recon ship and not well suited to the goal of flying a "combat" mission.
So off I go to another option that brings together cool factor and ease of assembly. I'm hoping to pull Craftydan into this one, but time will tell. He's a busy man and is tied up in another of my crazy projects too.
I'm going to build a Daimler Benz Projekt B carrier ship complete with its parasite planes.
The two parasite flying bombs will be simplified and drop as free flight birds in the bomb drop contest:
And then there's the little jet fighter. Should be a fun little critter, and I still haven't decided how I want to have it set up. One thought is to cram a 30mm EDF into that pod, but another is to go the fun, cheap route and stick rocket motor in there. Either way, it's going to be a similarly simplified model based of Estes body tubes and the like.
This should be a fairly simple build honestly. I'm not looking for a fast model either, so I'll probably go light on the power system and just produce a nice fun flier. Won't be hard to get a good power to weight ratio even with small motors and escs. I'm probably going to base the fuselage assemblies off Estes body tubes again just to keep things nice and simple. Might even buy balsa nose cones from Balsa Machining Service just to simplify things even further. Basically, it's an epic project that turns out to be pretty easy!
Design Specs
54" Carrier/ 22" Bomber / 8.8" parasite jets (1/40 scale)
Carrier:
2xPower Pack A Twin Engine sets
- 4x 1806 motors
- 4x 6x4 props
- 4-7x micro servos (anything between 3.7g and 9g will work), need up to 3 extra servos for releases if
you don't buy the kit
2x BT50 body tubes from Balsa Machining Service
1x BNC50X for cockpit (cut down to fit)
4x BNC50Y for tailcones
1-3x piggyback release
6-8 channel receiver (minimum functions: R-E-A-T with passive piggyback release, R-E-A-T+Aux for single or combined release)
3x sheets waterproof DTFB
6x wheels
1x 3s 1800-2200mAh lipo carried under wing
Velcro for mounting rx and battery
1/32" plywood for control horns
.042 piano wire for pushrods
Jet Bomber:
2 extra servos from twin engine powerpack for Carrier (used 9g servos for wing and 1 3.7g servo for elevator because I had them)
40mm Dr. Mad Thrust EDF
20A ESC
6 channel receiver (R-E-A)
1x BT60 body tube
1x BNC60AH for tail cone
1x BNC60MS for nose cone
1x sheet waterproof DTFB
1x 3s 800 mAh 30C lipo
Parasite Jet, RC (up to two of these):
1x AR6400LBL rx/servo combo
1x Parkzone long throw linear servo
1x 2s 200-300 mAh lipo
1x Turnigy 1220-10500kv inrunner
1x GWS 2.5x0.8 prop or similar
1 sheet 1/8" balsa for fuselage
1 sheet 3/32 balsa for wings
1 sheet 1/16" balsa for stab and sub fin
Blenderm tape for hinges
.015" piano wire for pushrods, elevator connector, and carrier hook
1/64" plywood for control horns
velcro for battery attachment
1/16" aluminum tubing for elevator pushrod guide
Parasite Jet, free flight (up to two of these):
.015" piano wire carrier hook
1/32" plywood for catapult hook (optional)
Plans now available.
View attachment DaimlerBenzProjektB.zip
Builder's guides for the jet bomber and carrier ship are now available in my model plans drive:
https://drive.google.com/open?id=0B9t_4cR6_fI7QjhEdlNYOW1qd3M
Design Specs
Carrier:
- 4x 1806 motors
- 4x 6x4 props
6x wheels
Jet Bomber:
20A ESC
1x BT60 body tube
