Namactual
Thanks Damo. You are right, I should just stick with the 50's for now.
And on that note, she is pretty much ready. I need to install the RX and clean up the wiring, but other than that she is good to go.
I am using my gut for CG, but with this straight wing it is a no brainer. I have plenty of area to move the battery to get the CG dialed in.
I used DamoRC's technique for the seamless nosecone. It worked great, thanks brother!
Now I just need to work on my overall build quality.
Speaking of which, that's my biggest complaint with this build, she is a little rough around the edges. Hopefully the beta will be cleaner once I dial in the fitment.
Major changes incoming are as follows:
1: Higher wattage fans.
2: New wing spar and ribs. (to fix airfoil and dihedral issues)
3: Add functional rudder
4: Tighter fitment, and hopefully a cleaner lighter build
My biggest worry for the maiden is the TWR. I have flown FAR worse, just not with so many unknowns on a scratch build. I have confidence in my thumbs, but I will have some butterflies for sure.
I am not sure when I will get around to the maiden, it might have to wait until next weekend unfortunately. Work is going to be rather busy all week. We shall see.
