Okkeedokkeee... so i may have taken a bit of liberty when it comes to the power-plants, but was hoping to test fly this monster this afternoon before finishing it up.
Seriously, if this model isn't picked up for the master series, its a travesty, this is an absolutely beautiful model, based on a one of a kind aircraft, that went together perfectly. Localfiend you should be very proud, this is a work of art, thank you so very much.
Ive got two Turnigy D3530\14 1100kv rated to 315 watts apiece, meaning this should be almost 7/8 horsepower... making this the most powerful one built yet(unless somebody's got one that they've just not been sharing with us) I have a couple 1500mah 3s batteries, and seeing as how the battery is right over the CG, a few heavy 3s 5000mah batteries that should give me flight times of 30 mins at 50% throttle. i gave it a quick punch of throttle last night, and at about 75% it"ll climb vertical, at 100% i had trouble holding onto it... I gots me a jen-you-wine space shuttle
AS my motors are wider than the motor tubes, i decided to just print the entire motor pod. printed out in PETG, 3 walls 50% infill... and im not too terribly sure this is a good idea. i need to build a ruler one and compare them. its certainly stronger, i would snap a wooden one with the bending force ive put into it, but they've got some twisty flex to them that might need to get designed out. Ill put up the files, but i wanted to cover it with foam, take some measurements, and make a skinned version with some internal improvements before i put it up on the online.
CG is exactly 1/2 inch behind where it should be without a battery, i think i can change the mount a bit to get it to where it is supposed to... how exact of a science is figuring out the CG?, will that be too tail heavy? surly not right? i still need to weigh it fully assembled, not sure what takeoff weight is with the different battery configurations.
i also need to get a amp meter on it, my multi-meter was in my work bags, so ill make sure I'm not pushing the motors too hard with the four props, but all and all everything accounted for, i should be putting a 7/8th horsepower plane up, depending on whether i can hit that with this prop combo...everybody was saying how this model could use some weight, i thought it a waste to not make as much of that extra weight motor
i beveled all the control surfaces, and still need to put on the outer skin panel and final edge piece, and the motor pods.
Ive also have a fpv camera setup i want to put in the nosecone/ cockpit, but dont wanna try my luck just yet. ill get it in the air, then worry about the extras.
