Vimana89
slender delta is repaired. The nose was quite a bit more torn up than I thought on first look. It it came back together nicely with a little hot glue. I will post pics of the new cg. The old cg is visible in the main challenge thread.It would not fly with the first cg, it was too far back. I brought it too far forward by setting the battery as far forward as possible and that was a flop. Right about where I have it now got it to start flying, but anemically. The prop cap was a little loose too. I added 56% negative expo. I'm not using dual rates because the elevons don't have much down travel to begin with. I will try when I get a chance with the new cg and expo settings and see if I can get it to fly right.
