Build Rating:
Fly Rating:
Plans: I have a problem linking to them because
@mach1 rc hasn't publicly posted them at least not that I know of so I rather get his approval to post them before I do.
@Randomkid87 could you please ask him if I can post them?
The reason why I choose to build this plane and make it the first on my list is because
@mach1 rc asked if I could test out his design, and I happily agreed to help and give him my feedback.
The build itself is not complicated but does include quite a bit of work with poster board so if you don't feel comfortable with poster board masking I recommend you get some practice working with that. I did have some issues with the tail boom either because of a mistake I did or because the plans need some fine tuning but a part from that everything else went along just fine. Unlike the original design I made the wings removable by copying the technique used on the Spitfire. My guess for the estimated build time on this build is 6 hours, working without long breaks. More about the build process can be found on later posts.
I'll give this build an overall build rating of challenging just because the plans are not a 100% fine tuned and thus requires a bit of thinking and working around problems, however once the plans will be finalized this plane will easily fall into the moderate build level category.
The first few moments of the maiden were cut out of the video as my flying was sketchy and the plane needed some trimming, once I dialed it in she flew great. The model does require speed to stay air born and stable, it can slow down but only so much before it will stall on you. One thing that I noticed is that the model will want to wing stall on you on tight turns so be aware of that and prepared to deal with it. I do have an idea of how to fix that and I believe that copying the poster board wing tip trick like in the FT Racer should solve the problem or at least help with that. I am rating the flying of this model as hard because of the wing stalls that will cause a less exprienced pilot crash.
Overall to sum up my exprience with this model I will say that this is not a plane for a new builder or pilot but is defenatly a fun plane for the more exprienced.
