This is my entry for the FTFC20 Classic to Modern Forum Challenge!
(in the hopes that opening a thread will help me get my butt in gear...)
The Subject is the Carl Goldberg "Electra", an electric powered glider from the late 80s/early 90s
The Electra was my first powered rc plane and, at the time, a bit of a disappointment.
Running a Mabuchi 550 brushed motor with an 8x4 prop on a 1300 mAH 7 cell Nicad this thing was not only underpowered and struggled to climb but the added weight made it kind of a pig in the air once you gained enough altitude and tried any kind of soaring.
I was told the plane made an excellent glider once you removed the battery and prop but my high start attempts proved less than successful
After I crash I ended up shelving the plane, along with RC flight for the best part of the 90s and 00 years until Flite Test and some gentle coaxing from a few friends brought me back.
I still have the fuselage that I cobbled back together from the splinters I picked up at the field and the wing which is mostly undamaged at home.
In a bout of nostalgia I also bought an unbuilt kit off of my local hobby shop a year or two back, So I got the original plans to work off of.
Design brief is as follows:
Caveat: I've been known to start projects that I never finished, mainly by overcomplicating things and then getting distracted by the next shiny thing.
Here's to hoping that doesn't happen this time...
- I will mostly be using Flite test building thechniques since the boxy fuselage and square-ish wing lend themselves to it.
- The plane will be RET, as was the original.
- The FT alpha I built for Flite Fest this year will be the donor for the F-Pack used to power the plane although I'll be going for 9 gram servos for the control surfaces.
- A folding prop might be in the planes future but for now it'll be the 6X4.5(?) that came with the F-pack.
- The goal is to have as little exposed foam as possible
- As with the original Electra the Battery will be located right under the CG so you can up the capacity for longer powered flights and reduce it for better soaring performance without too much hassle.
- I'll be going with 3D-printed FT-style hardware for control horns and the like. [Link to the original creators thread/thingiverse will be included here in the future]
