Additional thoughts:Let’s talk washout.
Seems to be pretty common in the designs I’m looking at (“might” rhyme with Sweet Pea)....
So, I’m not sure there’s an easy way to do that in foamboard. One option I saw was simply build it with each (both) ailerons a tad up (above the wings surface.)
I also wonder if this is why we see undercambered wings on most FT designs?
Thoughts/comments?
Washout also relates to adverse yaw. While the FT undercamber approach does prevent the "tip stall" issues similarly to washout, it does not address adverse yaw associated with this approach. Generally, FT overcomes this by having and increase in vertical tail area. Overall these are inefficient approaches because if the increase in drag they inherit. Proper washout will have the best of both worlds without needing to increase the vertical tail area. The advantage in a model is that you have a much longer glide path when unpowered and you have less of the typical FT "plop" landings.
