FTFC20 Half-A Chaos designed by jfaleo1
jfaleo1
Entry two is another I have started this was an article with two projects I have started the Chaos because I had a 60 size version many years ago.
F-pack should o the job here.
  • Half-A_Chaos_RCM-607-A_oz9211_article.pdf
  • Half-A_Chaos_RCM-607-A_oz9211.pdf
jfaleo1
V2 plans added 8-8-19
reserved for build log and plans
  • Half-A_Chaos_V2 fuselage JTF.pdf
  • Half-A_Chaos_V2 wing JTF.pdf
TEAJR66
Flite is good
Very nice. There are a few 1/2 A planes from the OuterZone dot com collection that I have done in foam board.
1806 motors with 5x3 props and 500-1000mah 3S batteries work well.
2204 with 5x5 props and same batteries are pretty sporty.
I've done the Sharkfish, Cannon ball, and Cherry bomb. With the Cherry bomb being my favorite. There have been others, but they weren't very memorable.
Cant wait to see your results. Good luck.
jfaleo1
Added my V2 plans to the 3rd post. these are just for prototyping so anyone trying them it is use at your own risk... I'm still working on the airfoil and how to make it right. This is a starter pattern ship to move ahead with an airplane designed by a man who I used to fly with. I have all the plans for the design but I can't decide if I will build it as a foam and fiberglass, balsa, or foam board model. Or all three. so practicing on this design.
jfaleo1
Foam cutting has begun on this one. Photos to come, but so far so good. Minor tweaks and plans should work. Motor decision still to be made. I have a 2208 that may go here.
jfaleo1
Well, fuselage is pretty good. C pack electronics, may be overkill but plans were slightly enlarged. Wing is not what I want yet. I think I will make another but I will use rubber bands so I can switch it out with a new one. Needs to have a slightly wider cord and I am going to give it a better symmetrical shape, I think I will use ribs like I did in the Quiky with no paper ob the inside. Also I need to dig out a spinner for this just because. A few fuselage tweaks and it should work out ok if I can get the wing fixed. Pics later, no build pics yet since I am not happy with everything at all so another will get done for the build log, if it works out well enough.
jfaleo1
Not quite ready to fly but all it needs is radio and servo setup and velcro for the battery. only very slightly nose heavy. It is light but this version of the wing is going to stall (and tip stall) easily. Should fly, just not sure of how well.
SlingShot
Maneuvering With Purpose
Looks good! As a side note, in the pre-Quikie 500 days, we had Sport Pylon. The full-sized Kaos/Super Kaos was quite popular in that role.
