Alright folks so V2 has been flying for a while now and I love it! So far the weight of the bird using the under-cambered wing design is 455g, excluding the battery. So far V2 of this model has been tested with two different power setups. Setup 1 is using a B pack motor, 10x5 prop and a 20A ESC makes a nice slow flyer, needs more run way to take off/land and can't do any special manuvers but flies nice and steady. Setup 2 is using a C pack motor, 9x4.7 prop, and a 20A ESC this setup turns the bird into a speedier aircraft, allowing short take off/landings and has better handling in the sky to do manuvers. Both setups are fun and both can be flown in wind ranging between 0-18km/h which is what I was able to test fly the plane in. So far I have been able to balance the plane perfectly with 3S batteries ranging from 1000mah - 2200mah, but I believe that this plane can handle big batteries. Maybe on of my next test will be to parallel two 2200mah batteries see what flight time I can make out of it. Do to the large space inside allowing for big batteries to go in I think it can be used for awesome long distance FPV.
Any how here is a short video I made of the last time I took it out, enjoy.
I think I might release so beta plans soon so others can attempt to build it and comment the build process prior the end date of the challenge that way I can address any problems others might encounter before the challenge is over
