Thank you @Hondo76251 ! History she does have. Should I get this flying more reliably, I will be sure to put in some accouterments. such as an internal camera, and a matchbox for true historic effect:Awesome build man! Unique plane for sure, love any oddball airframe with history...
Looks like she might be kinda tail heavy still. Where does she balance at?
(the 1925 Essex was one the first affordable enclosed automobiles.)
Tailheavy - that is possible. after 3 years, I am still trying to figure out what Tail heavy looks like. (I've gotten better) Check the Vid @3.21, it is about a 3/8" behind the wheels. I will put some weight behind the firewalls, next flight, or a slightly heavier battery. I know I'm close.
The Flight:
Let's take apart those three seconds. First I have to gun it to taxi properly, so the motors are pulling hard. once it leaves the ground it lifts up and I adjust throttle, so I don't flip here. Then down elevator it levels out and I throttle back up. I punched back in a good amount, and it leveled out and I tried to find the down elevator that would allow me to try for more time. next, Port wingtip dipped, and it started to turn. I eased throttle and I tried to correct. first with the roll, then up elevator, but too late. I might be able to cobble together another flight before too long.
