JasonK
Participation Award Recipient
- ~100g kfm wing (own design)
- FT mini-F22
- ~250 kfm wing/FPV (own design)
- STOL V-tail ?Trainer? (own design)
Great designs! And I really like the way you lay out the project and description. I seldom have the discipline to write out what I would do differently next time.~100g kfm wing
Picture, plans link, why chosen
View attachment 191508 View attachment 191509
plans: see build log, this is a custom design for this challenge.
I picked this design because I wanted to try a kfm wing, needed a replacement for a crashed FT dart, and after cutting the main wing and peeling removable paper, found that with the correct parts, this could hit about 100g (less, but just over with the parts I have handy).
Build Log
I started with mocking up the wing in ecalc, with a few modifications to have room for a 6in pusher.
Extra measurements needed beyond the ecalc layout
Parts/Equipment needed:
- Fold over 3.5" in the center, 2" at wing tips.
- Elevons are 0.5" at the wing tips.
- winglets -> 2" tall, 4" long end, 1"x1" diagonal out of rear bottom, top is 2.5"
Assembly instructions:
- 1 sheet DTFB (I used Ross, slightly heavier, but stronger)
- 1 BBQ Skewer
- Gorilla Glue (Optional - used were possible to reduce weight)
- Hot Glue
- Receiver
- 2s 650mAh battery (smaller would is likely fine, this is what I have)
- 2x 5g servo
- 2x pushrods
- 2x control horns
- 1106 4500kv motor (FT gremlin)
- motor mount
- ESC/BEC
View attachment 191364 View attachment 191365 View attachment 191456 View attachment 191473 View attachment 191474 View attachment 191475 View attachment 191476 View attachment 191487 View attachment 191488 View attachment 191489
- Mirror the fold over parts at the fold over then cut out.
- double bevel cut both at the fold over point and at the elevon joints
- remove paper were the foam will contact itself
- cut 11" BBQ skewer
- score 11" channel centered on the wing 3.5" from nose to press BBQ skewer into
- place BBQ skewer in channel and fold over both wing edges to lightly indent were the BBQ skewer lines up, then lightly score and indent
- Glue fold over parts down with gorilla glue (or glue of choice) with BBQ skewer in place.
- Reinforce hinges with hot glue
- Glue on winglets
- cut out servo mounting points, I measured 4" from the center line just behind the BBQ skewer, draw a 1/2" back (so from 3.5" to 4" from center), place down servo, trace out, then carefully remove 1 layer of foam. I had to partially cut one of the mounting bits off the servos to be able to put the servos fully in, as the BBQ Stick was in the way and I didn't want to break the Stick for the servo. This placement of the servo, gets it almost on the CG, which given the shape, most of the non-wing mass will need to be in front of the CG target to get the CG at the desired location (3.75-4.00" in from the nose).
- Glue in the servos and control rods
- setup pushrods to give 1 thickness of foam-board of reflex (this is currently a guess for how much is needed)
- solder up/prepare electronics (varies depending on exact choices)
- mount motor mount on the top middle of the craft, as far forward as possible, while giving a small amount of room for the prop.
- Mount remaining electronics so that the CG is in the correct place, I left a bit of room in-case I wanted to put a micro FPV AIO on the nose.
- I mounted my battery to the bottom with velcro, giving the most ability to adjust CG by moving it possible.
Maiden Video
flight notes:
- Flight 1 -> mess up the elevon mix and had roll backwards.
- Flight 2 -> needed increase in elevator deflection, didn't have very good pitch control.
- Flight 3 -> had upped both pitch and roll gains and moved the CG back, got to sensitive in roll
- Flight 4 -> removed the extra roll dual rates, trimmed some roll and pitch before launch and flew fairly well.
Post-Project Reflection
- Time Taken
- Cutting out: 30m
- Assembly: 2h (less if you don't need to solder up your electronics)
- Painting: 30m (mostly hand painting time)
- Dry Weight: 108g
- AWU w/ 2s 650mAh Lipo: 146g
- Build Difficulty: low
- Flight Difficulty: low-medium (flies nice, but hard to track in the sky - at least with the current paint job + the time the maiden was done)
- strip paper after doing bevel cuts (I have a jig that makes them fairly easy, but pulls at the foam if not covered)
- block painting in sub assemblies can make some painting work much easier
- the fold over of the kfm wing needs lots of pressure to hold in shape while the glue is drying, I needed to use a board with 10+ lbs of weight on it to hold the wing flat while the gorilla glue was drying.
- One thing that I have found that I don't like with wing/wing like flight things is that it seems like there is a big thrust and/or speed impact to pitch. With the motor mounted above the wing with no down angle, I expected to have issues with thrust pushing the nose down, but I didn't have any issue like that. I did however have issues getting the pitch trim done well, perhaps a throttle thrust -> negative elevator mix would improve this.
- Durability is great, multiple landing, some of them rather rough and no viable marks/damage that I could find to the wing itself.
- After getting the dual rates/trim/etc setup close to what was needed it flew rather nicely.
- One thing that I ran into was 'flying on the wing' as basically everything I have flown before now was at 1:1 or better thrust:weight ratio, which being able to push your motor to 100% and forcing your way out of a situation is definitely different then being 100% reliant on the lift from the wing working as expected.
- The plane seems to have quite a bit of drag, this is probably a mix of all of the exposed electronics and possibly the kfm wing shape.
Hard to say.Your blogs are wonderfully detailed. And I look forward to reading through your take-aways.
@JasonK , Which one was your favorite?
