FTFC'25 WWII P63A designed by ezbruh
ezbruh
janky mighty mini swappable power pod installed
ezbruh
Tail is on! Now I just need to put in the servos and control horns for the rudder and elevator and make a canopy. I’m almost done building! Oh also I made a turtle deck and I used one of the plastic prop washers to decorate the little air scoop thingy it has.
ezbruh
The crop circles all over the plane are because it’s easier to draw perpendicular lines than tangent lines and tangents are always perpendicular to radials and radials are easy to draw. The esc has an xt-30 and my only battery has an xt-60 so I’m getting another one along with some adapters for the future and some markers because why not.
ezbruh
here is the dxf so far. all its missing is some servo cutouts and a canopy.
  • Sketch 1 Drawing 1.dxf
ezbruh
Reinforced the tail, added the rear gear and installed the servos for the tail. They’re kinda hiding in this picture.
ezbruh
I haven’t centered them so the screws for the horns aren’t in and neither are the control horns in the back, I’ve just routed the pushrods through the straws.
ezbruh
Redoing the turtle deck because it didn’t look right. Also battery hatch.
ezbruh
I just noticed it looks like I glued the antennae in place but they are fed through little sections of straw that happens to be the same color as the glue
ezbruh
That’s the build finished! The battery and markers are set to arrive today by 9:00PM which means the maiden will be tomorrow or the next day. Eeeeeeeeeeeeeeeeeeeeeeee
