FTFC'25 WWII Saab J21 designed by FlyerInStyle and MiniacRC
yeah there will be a skewer in the hole plus a doubled up tail boom, and I accounted for the fact that the tail will be weaker. Its made for a 5-6" prop, not sure if 6" will fit but it'll land like any other mini plane with a 2 bladed prop, not really worried about that
That’s what I thought, looking good so far!
FlyerInStyle
Everything except for the wings is unfolded! hopefully will start building over the weekend and have it flying next week.
FlyerInStyle
here are the pdf plans without wings, tiled and untiled, if anyone would like to take a look
  • j21 no wings tiled letter.pdf
  • Plans for j21-no wings cropped.pdf
FlyerInStyle
So I realized a) how to unfold the wings, and b) I made the plane 1.2m in wingspan on accident. I decided to take a relatively drastic measure and scale it down almost to 1/2 scale. I did get a full plan though, attached is a proper full and tiled plan, should only be 1 sheeto f foam really.
  • j21 tiled letter.pdf
  • Plans for j21-full.pdf
Looks nice!
FlyerInStyle
Got some updated plans, this should build much nicer, if anyone would like to take a crack at it. I am still building mine and hope to fly it soon
  • Plans for j21- updated sheet full.pdf
FlyerInStyle
Update: did some test flying, it looks like it doesn't glide at all in the video, but it does, just st poorly, but I have had more overweight aircraft fly. When the winds die down I'll try to maiden it. I think removing all the inside paper and not using humongously heavy electronics from larger aircraft would've helped to. If you want to see me test/ fool around with it for a bit, here is the video:
Was it nose heavy?
