NL466RCFlyer
Hi,
I am a brand new Flyzone Sensei RTF owner. It is my first 4-channel (actually 5) after starting with a Hobby Zone Champ RTF but I have been putting off the maiden flight because I have run across what I consider a problem. This morning after finishing the assembly of the plane and running some tests with the radio I accidently shut off the radio before unplugging the plane. When I did the plane went to full throttle! Luckily the prop wasn't installed at that point.
I know that turning the radio off first was a mistake but this could happen accidentally at any time. Is this normal? Is this what would happen if the plane lost radio contact? Should I reprogram the failsafe? Would that fix the problem? A little advice is welcome from anyone.
Carl
Carl
