Mode 1
Hi All.
My building binge took a bit of a twist as I ended up with a fuse on a mini scout that is not square. I'm not even sure how it happened as I used a triangle. It's as if the section beyond the "bend" (rear portion of the fuse) is at a different off square angle than the main portion of the fuse... like it twisted a bit. What can I expect from a flight perspective?? will it fly ok after a trim or shall I rebuild the fuse? Also, is there an easy way to remove pieces that have already been glued on beyond just cutting it off? Thought I heard somewhere that alcohol will loosen the bond of the glue.
Many thanks for any feedback.
~Dave
~Dave
