Gadeirus' flying things
L Edge
Is that a "GLH" pylon racer that is sitting on your bench? Fast little plane with a TD 049!!!!
Gadeirus
The Dumble Dee
Small one? I have my drawing for the parts but they may not make sense to everyone. If you can give me a bit of time I can make them more usable to other people. Can do the same for the big one, too.
They do use some 3D printed parts, I don't want to assume everyone has access to one.
TreadHead98
Great! I’m actually interested in the big one, and I do have a 3D printer, so printed parts are no problem for me. I’d definitely appreciate the drawings/files whenever you have time to make them shareable.
Gadeirus
I haven't forgotten about you, I'll get to it, need to finish a few other things up.
Gadeirus
I finished my latest edf build, no pics yet and haven't had a chance to maiden yet.
On a separate note, I bought a box of random stuff from someone recently and included was this motor, it's a little FT Gremlin meant for drones. I see people used it on a nano flerken or something like that, too.
What do guys think I should design for it? It'll run on up to 4S, supposedly.
The Hangar
Fly harder!
What do guys think I should design for it? It'll run on up to 4S, supposedly. View attachment 260664
I believe I have a couple of those motors on an old quad that need repurposing… Would be interested in a project if you come up with something! I’ve always been a fan of pylon mounted motors (not sure if that’s the right term - but I mean similar to the sea Angel or sea otter) and I haven’t seen a small plane use that configuration yet.
Gadeirus
I kind of like that idea, I'll have to see what I can come up with
Gadeirus
Alright lads, it flies.
My latest attempt at an EDF plane, I don't actually have a name for it, it lives on my PC as "Magic VI" but it kind of reminds me of a fish so maybe that's what it ought to be called.
I have to tweak it a bit, it constantly wants to pitch up, even if I move the battery farther forward and doesn't seem to change with throttle setting, so I'm thinking it's an aerodynamic issue. Maybe it's the weird KF airfoil I'm using, maybe I glued the stabilizer in at an angle, not sure. Otherwise, however, as long as I keep the stick forward it flies quite nice.
So, need to fix the pitch up issue, maybe sort out some aileron differential, and do something about the batteries, they get hot. One, probably inadequate cooling and two, probably inadequate discharge rate.
It's a 50mm flycolor edf running on 3S, four 5g servos for aileron and v tail, dunno what it weighs, maybe 450g or so? Haven't put it on the scale.
I have more video than what I'm linking below, but my son is the camera man for these and....well....he tried. I've got to find a better solution.
Gadeirus
So, I did sort of what you suggested, this is the "Pondhopper"
It's quite small and the little drone motor on a 3S has way more power than it needs. Maidened it this morning, flies pretty well, and on 850mah I probably had it in the air for 15 minutes.
I was going to fly it again now to take some video but during a motor check before launch the propeller came off the motor and launched itself to narnia, so now I have to see about procuring another propeller.
The Hangar
Fly harder!
I really like that! Can’t wait for some vid (and plans)
I really like the landing targets! 🤣
