Maingear
Flugzeug Liebhaber
I ran across this aircraft at the Bearospace Industries website. Spike designed the original and the version 2 Gemini to be a long endurance FPV platforms. With 3 hr duration and a 20 lbs max takeoff weight, it was intriguing. Doing this with two power 15 motors, I clicked the buy it now button. The scroll saw, I picked up at a pawn shop, made cutting out the fuselage plywood a breeze.
Copied from his website:
SPECIFICATIONS:
WINGSPAN: 3200MM 126 INCHES
WING ASPECT RATIO: 10.77 / 1
​AIRFOIL: HIGH LIFT / NON CRITICAL TYPE MAX CO-EFFECIENT OF LIFT: 1.5
WING AREA: 96,000 CM SQ. OR 1488 INCHES SQ.
AIRFRAME STRUCTURE APPROX WEIGHT: 4 LBS, 9 OZ
EMPTY WEIGHT: 7 LBS
MINIMUM FLYING WEIGHT: 15 LBS / 6.8 KILOS
MAXIMUM GROSS WEIGHT RECOMMENDED: 20.75 LBS / 9.4 KILOS
WING LOADING: 23-32 OZ. -SQ. FT - 71-98 SQ. D.M.
FLIGHT DURATION : APPROX. 3 HRS WITH PAYLOAD
RANGE: AT LEAST 12 KM DISTANCE WITH L.R.S.
DISTANCE: APPROX 120 KM LINEAR WITH PAYLOAD
CRUISING SPEED: 40-70 KM PER HR
STALL SPEED AT MAX GROSS WEIGHT: 22 MPH / 35.4 KM PER HR
CIELING: UNKNOWN, BUT VERY HIGH. 20,000FT +
BEST LOITER SPEED: 42 KM PER HR
BATTERY CAPACITY 50,000MAH 3 CELL LITHIUM POLYMER
AMP DRAW AT 42 KM PER HR: 13 -17 AMPS DEPENDING ON PAYLOAD/BATT.
RECOMMENDED POWER: 2X E-FLITE POWER 15 BRUSHLESS ELECTRIC
RECOMMENDED PROPS: 13 X 6 - 13 X 8 APC THIN ELECTRIC 2 BLADE
RECOMMENDED PROP CONFIGURATION: COUNTER/ROTATING INWARDS
RECOMMENDED SPEED CONTROLLERS: PHOENIX EDGE 50 AMP +
RECOMMENDED SERVOS: HS 225 METAL GEAR TYPE FROM HITEC
FLAPS: DUE TO HIGH LIFT AIRFOIL, NONE ARE NEEDED
So here it goes, my first scratch build!
I built on top of the plans for the sides. The bulkheads go in and are to be cut to the fuselage measurements.
Fuselage is roomy
Here is a Nikon D90 in half of the rear bay, good indicator of size.
Had to bend some wood that builds up the ply in the top of the nose. I soaked the wood, then found something close to the shape I needed.
Tail was built by making perimeter, then adding ribs, then placing the 1/4 x 1/2 strips on the vertical stab.
Finished the H-stab, and elevator, will post pics soon.
Need to cut out some ribs! How should I cut the holes in the ribs when I have them stacked?
Justin
SPECIFICATIONS:
EMPTY WEIGHT: 7 LBS
Fuselage is roomy
Justin
