I've shared a lot of this on social media - and I've felt bad for not being on the forums in a while - so especially now that it's flown I want to make sure there's a place here on the FT Forums where I can engage, answer questions, and connect with everyone who isn't on the "other" places.
So let's kick it off, here's the maiden flight!
Here are the stats:
Wingspan: 24ft (1/4 scale of the real C-47/DC-3)
Length: 16ft
Flying Weight: 92lbs
Wing Loading: 22 oz/sq-ft
Cube Loading: 2.75
Speed: SLOOOOOW (for it's size)
Power: Twin electric high-power motors
Props: Xoar PJWWII-R3 3-Blade 30x12
Battery: Two 6S 6000mAh in series per motor (12S voltage)
ESC: Jeti 300A
Receivers: FOUR FrSky X8R on two FrSky RB-10 Redundancy Buses, segregated between wing and tail controls
Servo/Rx Power: 12 Tattu 2S 2200mAh in distributed/parallel plugs
Materials: Foamboard, styro-insulation foam sheet, carbon fiber tubes, plywood, 3D printed PETG, strapping tape, hot glue, Gorilla Glue and epoxy.
Taxi test:
There are a ton more videos on my channel, you can see them all in this playlist:
https://youtube.com/playlist?list=PL-iCijBhaPzAUnmSJQQht1I4rJLL4WdCt
HUGE thanks to all my partners and sponsors, and especially my awesome wife! I couldn't have done this alone!
https://windcatcherrc.com/
https://alofthobbies.com/
https://www.xoarintl.com/rc-propellers/
And of course, Flite Test.
Here are the stats:
Length: 16ft
Cube Loading: 2.75
ESC: Jeti 300A
Taxi test:
