Gaz.Spencer
A friend and I recently set out to build a big plane, and now we did it. In under about 10 hours work put together. Hopefully a flight video will come soon.
Setup:
-Hobbyking Donkey 810kv Outrunner with 12 inch prop
-Hobbyking 30 Amp ESC
-HXT900 9gram servos (Should be enough
-3300mah LiPo
-Turnigy 9XR Rx/Tx
Specs:
-Length= 1.2m
-Wing Span= 2m
-Weight without Batt= 1600grams
Here are some pictures:
Some things to be noted are that I changed the position of the wing from the real Storch, as well as the Tail. The landing is more of a temporary thing, before I can get some real landing gear.
Setup:
-3300mah LiPo
-Turnigy 9XR Rx/Tx
Specs:
-Length= 1.2m
-Wing Span= 2m
