Bonus points if you know what kind of composite reinforcement fabric this is.
I did a couple test runs and found that laminating the balsa skin right onto the composite fabric in the vacuum bag usually resulted in the fabric creasing around the edges of the balsa sheet. To alleviate this problem I wet out the fabric with fast curing laminating epoxy and vacuum bag it first without the balsa. After two hours I remove it and add the balsa sheets. Here’s a photo of the fabric in the mold after removing it from the bag. I used perforated release film rather than peel ply. This allowed me to carefully remove the assembly from the bag without disturbing the partially cured fabric in the mold.
Then I glue the balsa sheet on with gorilla glue and vacuum bag it again to hold it tight. This doesn’t require release film or bleeder ply, so it’s quick and easy.
After letting the completed layup cure for a few more hours I had a perfect part.
