A quick note about this new thread - it won't get in too deep as this plane doesn't need a ton of work. My thought behind a lot of these short threads is to show people new to balsa how they can get a used plane that needs a little TLC and get it back into the sky on-the-cheap. Balsa is not something to be feared, and with a little effort you can take a very cheap & rough plane and give it another decade of life. On with the show!
One of the nice things about having "too many planes" (according to my wife) and knowing other people in the same predicament is that there are sometimes trades to be made. In my hangar is an un-built Kadet Senior kit and in my buddy Mike's hangar is a used Great Planes Cherokee he recently acquired, complete with a Rimfire motor, ESC, and servos.
At face-value it's a lopsided trade in my favor, so to even it out I'm throwing in some parts needed to get his Sig 1/4 scale Cub airborne, plus the labor to mount the engine, gas tank, etc. He REALLY wants to build a Kadet Senior and I REALLY don't need a second one, so quoting John "Hannibal" Smith of the A-Team, "I love it when a plan comes together."
There are other projects ahead of it, but I needed to go through and check it out to get whatever parts are needed as this should (hopefully) be a quick project. The prop has already been removed to find out what size it is, as one blade is cracked. An omen, perhaps? A previous owner went a little overboard with decals for my taste, so I'll remove some to clean up the look a bit.
Other than a few small cracks in the plastic canopy the worst part is the tail. The covering has a lot of bubbles and the rudder has no throw to the right due to the way the hinges were installed. I think it's the original vertical stabilizer and rudder, but at one point they were re-hinged and re-covered.
Removing the vertical stab broke the nose on it. Not a huge issue, I'll cut new pieces and start fresh. There should be enough sheet material in my stash to do this all without buying anything. Hopefully the white covering I got for my big Cessna project is the same white for this plane!
As mentioned, the hinges for the rudder are an issue. Here's full deflection to the left, and notice how the rudder (to the right in the picture) doesn't line up with the vertical stabilizer? The hinge is way off center. I could probably just fix what is already here, but it's a bit rough and cutting the new pieces is fairly easy.
And here is the total throw to the right!
A little patching of the covering is also needed at the tail. Not sure if I'll just re-carve this entire block or not yet, but probably not. If the plane were in "new" condition I would, but this isn't going to be a show-piece.
Moving inside I'm test-fitting my 5 cell 5000mAh battery pack for my big electrics. It's snug, but fits! The instructions call for taking a 3S 3200 and a 2S 3200 and combining them to make a 5S 3200, but I'd rather not drop a bunch of money on battery sizes I have no other use for. The 5000mAh packs also work in my 1/4 scale Pietenpol, the Kadet Senior, and an Astro-Hog. When I checked the balance the nose was slightly down, perfect for a maiden! Then I noticed about 1-1/2 ounce of lead bolted to the tail, so maybe the previous owner used this same size pack?
