I found an issue while gluing in the R1 and R2 ribs. Great Planes designed this so the wing joiners will fit between the R1 and R2 ribs, so when you glue them in you only are gluing in little tabs (circled in the picture) that will be cut out later when joining the wing. When you cut these out the top spar will be unsupported, which is no big deal, but if you have any spring or preload on the spar like I do to line things up, it may come out of alignment. So, I glued in a little balsa stick (arrow pointing to it) to reinforce and hold things in alignment until the day comes that I glue (epoxy) the wing together. This added no weight but will stabilize the spars in that spot and it's easily removable later if it becomes a problem itself.
I don't really like how they designed this center section as it is very fragile when building, but it will be very strong after assembly, so I guess it works.
