I'm bored with working on the airplane upside down, so I flipped her over and am looking at my battery hatch idea conversion. I am thinking I will do a similar type of magnetic top hatch like I did on the Hog Bipe conversion. This should give me a good 6 inches of open hatch space to install a nice size 6s battery. The hatch on the Hog Bipe will not come off with the 4 magnets and is very strong, so I think my design is solid. But, if anyone has any input, I will gladly take a look at it. As you see in the last picture, I will need to fabricate new formers fore and aft for the hatch and the fuse and this will add weight for sure, also a battery tray will need to be made, but that is the easy part...The added weight probably isn't much more than the gas equivalent build, at least that is what I have found on my last few conversions.
BTW, the wing is mounted and I saw no reason to use the wing bolt tubes they wanted you to glue in, but if you had shorter wing bolts it may help to guide them in and possibly keep dirt out. You can always remove the wing and get in there to clean if needed and I felt the wing bolt guide tubes were just added weight and a pain the ---.
Hog Bipe hatch.
The canopy sure looks nice in this kit!
