Again, I would not use CA. Epoxy epoxy epoxy. CA is far too brittle for such a critical joint.
I'm open to any ideas and I think I get your concept. It's worth a try. As far as the GP website I've been there many times and they've been unresponsive since the company that bought them out has gone BKO but Horizon has taken over but they're an empty suit as most of the real hobby suppliers have become. Very sad but thank you for your input.I've been following this thread with a lot of interest as I've always loved that model. I just ran a search for these parts and I did locate the parts listing for the GPMA2852 at the Great Planes website. Its listed under discontinued items and although the part is listed, they say availability of the part is doubtful. You might go to their website and do a parts request, can't hurt. Its hard to really tell in a 2D photo, but is the strut joint a fiberglass core right to the end? If so you might be able to make a new bracket out of an aluminum roofing screw flattening out the end on an anvil then drilling the end of the strut and epoxying the screw threads into the hole. Clear as mud???
After sleeping on it and examining the strut closely I think you're right on the money in terms of your idea. I don't have a 3D image of the strut post but the strut's thickness is approximately 3/16". I think I can center and drill a small 1/16" vertical hole in the end of the strut and screw in a small eyelet screw. If it works I'll unscrew it and epoxy it in place. Stay tuned and thanks again for the great idea!I've been following this thread with a lot of interest as I've always loved that model. I just ran a search for these parts and I did locate the parts listing for the GPMA2852 at the Great Planes website. Its listed under discontinued items and although the part is listed, they say availability of the part is doubtful. You might go to their website and do a parts request, can't hurt. Its hard to really tell in a 2D photo, but is the strut joint a fiberglass core right to the end? If so you might be able to make a new bracket out of an aluminum roofing screw flattening out the end on an anvil then drilling the end of the strut and epoxying the screw threads into the hole. Clear as mud???
That's another great idea, thanks but wouldn't I need to insert the ply into some sort of crosscut or slot cut into the fiber to get a good grip? Would it be strong enough to just epoxy the clean cut ends together?I would honestly try to make a clean cut across the strut and use aircraft ply to complete the cut off ends with epoxy, using the good one as a reference. If you want to fare in the ply piece you can use some lightweight sculpting material from the craft store. Then maybe do a finish coat of epoxy. The green on this airplane is pretty standard so it would not be hard to color match some paint.
Thanks for the kudos........I've never worked with Epoxy Putty before but this is incredible stuff, at least as of this posting. The real test will be under flight conditions. It's tested at 25# of "Ultimate Tensile Strength" before failing so considering the wing load, if my calculations are right, I'd have to put more than 17g's on it to fail. If it holds up I'd be willing to try it on bigger fixes.Hey man, not boring here. I'm taking notes if this ever happens to me! Looking good.
