Hi everyone,
I am brand new to multi rotors. I have flown a eachine 010. Built the Gremlin following TJ's video. Here is the current state.
I can get Betaflight to see and flash spracingf3evo one day to figure out how to get into DFU mode, whatever that means. I was also able to get my rx bound to my DX6. two days for that bc I soldered the signal wire one dot over.
I can connect with usb and Betaflight and see the gyro is cool. I can see the rx doing it's thing and have all the channels finally doing things correctly in Betaflight.
I flashed the ESC's with BLHELI and switched directions on 3 of the motors.
I can see they spin right using Betaflight sliders on the motor tab.
What I can't do is get the motors to spin using my tx.
I put an arm on aux 1 to switch A in betaflight
So disconnect the usb power up and the flight controller blinks. Motors beep like it is binding, the bind light on the rx stays solid. Camera works.
Cannot get the tx to do any thing.
Things I have tried making sure the fc is nice and level, tried putting the arm value to 1160 which is a little above my lowest throttle value. last 2 days
I know I am not seeing something obvious but no youtube or anything else I have found on the forums have helped. Can you guys help?
Getting soooo clooooose!
