Hello,
Just built and maidened my FT gremlin. All is flying smooth but about 30 seconds into flight the motors spin the props right off. The shaft on the motor isn't long enough to support any retention from the top of the prop, and I don't want to glue\epoxy them in place for obvious reasons.
Anyone else had this issue and found a work around? Or should i just buy new props and replace them when this happens?
Using a 3s 850 mAh.
Thanks in advance
Using a 3s 850 mAh.
Thanks in advance
