Mandoman21
Im in the process of a 6 month engagement trying to get an FT gremlin quad into the air. Ive already fried the stock hglrc vtx, (rookie mistake) and went and bought a whole different flight stack because I was having such a hard time using the hglrc stack that comes with the turbo gremlin power pack.
So, I recently purchased the luminier lux mini f7 flight stack. I was able to solder everything up no problem but ran into an issue with the uart placement of a Spektrum srxl2 dsmx serial micro reciever spm 4650. Initially I it soldered to tx3 of the lux mini under the direction of josh bardwell. However after that gave no response in beta flight I reached out to the Get fpv people and they pointed me towards the manual and said that there is a dsm pad for these types of recievers. So going against what bardwell said I soldered it up using the dsm pad. And it worked!
For a little..... I was able to put the receiver into bind mode through the beta flight receiver tab, bind it to my dx8 transmitter and register inputs and movement in the receiver tab when I moved the sticks of my transmitter. Then just like that it stopped working, and now I can't get it the the receiver to talk to betaflight again. I can bind the transmitter and receiver together no problem, I just can't get the transmitter to input any signals into beta flight and/or Im assuming the flight controller.
I wondering if it has anything to do with my laptop computer not being able to run beta flight correctly, or maybe its a defective receiver? Looking online I read that sometimes receiver inputs wont be registered if your CPU is too high, mine is around 100 when I try to get the receiver to talk. So in order to get it lower you turn off the accelerometer or mess with loop rates or whatever. I tried, didn't work, so I backed up the flight controller to what it was before I messed with stuff.
I really want to get this thing going, the whole process has been a bit discouraging. Maybe I'll just stick with foam board planes. Lol
Thanks for any help and insight, I really appreciate it!
https://www.amazon.com/Spektrum-SRXL2-Serial-Receiver-SPM4650/dp/B07P8N2SCB
