Grumman S-2 Tracker Foam Board Build
vhandon
I have built many FT planes, a few from kits but most from just the plans. I decided I wanted to build something different and it had to be something rare. I first thought of a building a Boeing 247 and I still may build one in the future. The obvious choice for me though is the Grumman S-2 Tracker. I have a special connection with this plane since my father was an electronics specialist and was part of the crew on one in the Navy. As soon as I find a picture of him with the plane I will post it. I have only found a few of these that have been built and flown and they were all large high-end balsa builds. I plan on using mostly foam board and achieving scale looks (from a distance).
I found good plans for a 63" wingspan balsa build that I am using as my template. I think I can power it with the FT Twin Power Pack C.
I am hoping to have flaps and retracts but static landing gear would be fine as well. If anyone one has a suggestion for retracts that do not come out of China please let me know. If not, I will have to order them soon so I can get this thing ready for Flite Fest Texas.
vhandon
Good find on the "Mini retract unit for RC planes" thing. I will be printing a copy of that one today. I am on thingiverse a lot but missed that one some how.
I already printed a copy of "Landing gear retract rc V2" but I am not in love with it.
Got a chance to print the Mini Retracts and I think they came out nice. It was a little work to clear out the built in printing supports, had to pull out the Dremel. I would prefer that the model leave those out and let the slicing software add them but just a minor nuisance.
These are definitely a contender but I also found a nice set from MotionRC that appear to be the right size and reasonably priced.
https://www.motionrc.com/products/flightlinerc-1600mm-f7f-nose-landing-gear-flw3021081#qa-tab
https://www.motionrc.com/products/f...ding-gear-left-flw3021082?variant=30792037516
https://www.motionrc.com/products/f...ing-gear-right-flw3021083?variant=30792038476
I guess it would not hurt to have both on hand and use the set that fits the best.
vhandon
Build Update 1
It rained all weekend so instead of flying at a near by event I stayed in and worked on the Tracker. I made some good progress. Hopefully I can keep up the momentum and get it built in the next few months.
Fuselage skeleton and and Tail:
Tail closeup:
Inside the Horizontal Stabilizer:
I had a few unknowns going into this project. Some I have think I have answers for and some that are still up in the air:
  1. How do I want to address the separate elevator surfaces? Should I use two servos or just split the control rods and use one?
  2. How do I want to finish the outside? Paint or some type of wrap or coating?
  3. How to mount the wings? They need to be removable for transport.
  4. Should I install the electronics under the wing or from a hatch in the bottom that is accessible when the wings are installed?
  5. Finding the CG? I never seem to get this right on the first attempt.
Think I will tackle the wing next.
vhandon
Build Update 2
The rain continues so the build does as well.
Took me three attempts to get the wing exactly the way I wanted but I am happy with the results. Everything is fitting together well so far.
Received all the electronics except the landing gear tonight so I will try to get them installed this weekend along with all the control surfaces. And maybe clean up my work-space if I have time.
vhandon
View attachment 114358 View attachment 114359 View attachment 114361 View attachment 114360
I went ahead and ordered the retracts from MotionRC. They are very nice but they are too big for this project. I knew I was taking a chance without more precise measurements but I am sure I can use them on a future project and i'm only out about $70.
vhandon
Build Update 3
Since the retracts are not going to work out and I don't trust the 3d printed ones without real testing I decided to install fixed gear. I was also able to get all the electronics and control surfaces installed. I reinforced the wing and figured out the mounting system.
Front Steering installed.
Here it is standing on its own three wheels. I will need to add a tail wheel or drag.
I learned a new term when researching how to connect the split elevator surfaces to one server. In my short time in the hobby I had never heard of a Triple Rod Connector. I found some online but not at any local hobby shops. I did, however find something that would work at the local hardware store. Found these in the electrical aisle, a package of two for $7.
Hope to get the motors mounted and start skinning it this weekend.
vhandon
Build Update 4
Finished skinning the entire plane and mounted all the motors. Just realized I did not test the motors yet. Hope I left enough room to get them out if there is a problem with either one. I think I lucked out with the CG, two 2200 3s in front of the wing seems to balance perfectly. Without the batteries the plane weighs in at exactly 1300 grams. I think the twin C power pack should have enough power to get it in the air. All that's left is a lot of sanding, filling, sanding, filling, sanding, then paint. My other hobbies include automotive paint so I am used to the sanding and filling associated with body work.
DamoRC
Build Update 4
View attachment 115432 View attachment 115433 View attachment 115434 View attachment 115435 View attachment 115436 View attachment 115437
Excellent work!
DamoRC
