Mr. Gandalf
Three things I would like to suggest you try.
1) set your control surfaces for 2 rates. One for low and the other high with a good exponential. Mine uses very little movement at all.
2) Mine was very tail heavy as you can see so I had to inch my battery forward and finally solved it by moving the canard forward.
3) Try 3/4 throttle initally to slow process of trying to get it under control.
After adjusting, plane goes real fast.
Thanks, I do have dual rates set up, but mine seems to be nose heavy and the battery is already as far back as it can go while still being ahead of the prop. I will try launching at lower throttle next time I try a hand launch, and BTW, do you think thrust angle could be part of my problem?
