Is it possible to use the aircore core and install it on a guillows fighter kit?
F Ftmainac Junior Member Nov 26, 2013 #1 Is it possible to use the aircore core and install it on a guillows fighter kit?
earthsciteach Moderator Moderator Nov 26, 2013 #2 Do you mean sheeting the plane with coroplast or building the plane from coroplast using the plans?
F Ftmainac Junior Member Nov 26, 2013 #3 Using the airframe from the guillows kit and using the AirCore core.
colorex Rotor Riot! Mentor Nov 26, 2013 #4 AirCore - FlyZone's ripoff of the swappables. http://www.towerhobbies.com/products/flyzone/index_aircore.html
earthsciteach Moderator Moderator Nov 26, 2013 #5 If you mean using the electronics, it may work. How does the weight of each match up?
