Guillows Stearman RC Conversion
OliverW
Fuse pics! All I need to do is buy a motor! Second pic is it with a mini scout!
OliverW
I mean cockpit not turtledeck... Servos and servo tray installed! Unicorn head for scale...
OliverW
Progress.... Unicorn head for scale. Servos mounted in student cockpit.
nhk750
Aviation Enthusiast
It always amazes me how elegant the small airplanes look compared to the 60 size builds in the framing stage, looks great so far.
OliverW
Thank you very much!!! I have been watching your extra thread with interest. My Great planes RV-4 looked the same! The stearman weighs nothing at all...
OliverW
Got the stringers on the bottom of the fuse. Left half of the fuse. The right half is open so putting everything else in will be easy!
OliverW
Got the rudder and vertical stabilizer almost done. Just need to figure out how to put the control horn in on something this small
nhk750
Aviation Enthusiast
What a cutie! Our little dog always checks up on me too, and gets in the way of building, but what can you do?
TooJung2Die
Choose one of the 1/16x3/32" spars in the rudder and replace it with 1/4x3/32" to mount the control horn. You should have plenty of 3/32" scrap balsa that'll fit the bill.
OliverW
Thank you. The big problem is I may need to just make the bottom of the rudder be sheeting. I added a small piece of super light balsa for reinforcement. Be fore the whole thing could really flex.
TooJung2Die
You could certainly make the bottom section of the rudder more solid. Every gram of weight added to the tail equals four times that needed in the nose to balance. Covering adds a lot of stiffness to the tail surfaces. What you have now looks sufficient.
